Tie rod question
Old Feb 9, 2014 | 06:16 AM
BosoxJK's Avatar
Default Tie rod question
Can I replace just the ends?? Or is it like the draglink where I have to replace to whole thing? And does anyone by chance have the moog part numbers? Thanks in advance!!
Old Feb 9, 2014 | 08:08 AM
mattgt5's Avatar
I'm selling a stock tie rod if you need one.
sent from my work leash
Old Feb 9, 2014 | 08:39 AM
Ncb's Avatar
Ncb
The IPC shows the passenger side tie rod end as part of the assembly. The driver side tie rod end can be removed. I didn't look closely at my tie rod when it went in the dumpster to see how the passenger side TRE is attached. Probably welded or crimped to force you to buy the whole assembly.
Old Feb 18, 2014 | 12:34 PM
tackindy's Avatar
MOOG ES3624 for the Tie Rod Inner
MOOG DS 300005 Tie Rod Pitman
MOOG ES800594 is the Left Outer
And the Factory Part is 52060052AG with the built in sleeve
