Tie Rod Replacement
Old May 19, 2020 | 08:08 AM
csichoice's Avatar
Default Tie Rod Replacement
I need to replace my tie rod ends should i just replace the stock ends or upgrade to a stronger Tie Rod altogether? I have a 2012 JKU Rubicon running 37's.
Old May 19, 2020 | 08:15 AM
karls10jk's Avatar
Absolutely upgrade the entire thing. The pieces for the stock tie rod, assuming you go with minimum acceptable level parts, will run you in the same ballpark as upgrading.
Old May 19, 2020 | 09:25 AM
resharp001's Avatar
Loved
Community Favorite
Be glad that TR made it this long. Time to start upgrading your steering . If you're even the least bit handy (ie. you can install yourself), you can "build" a nice aluminum TR either via Rought Stuff, or even cheaper (more of a DIY) like this -
https://www.jk-forum.com/forums/modi...ie-rod-346539/
TR's usually aren't cheap, but they don't have to cost an arm and a leg. Whatever you do though, definitely something that is better than stock if you're running 37s.
Old May 19, 2020 | 11:15 AM
Seizer's Avatar
What they said upgrade it. MOOG makes a decent tie rod with lifetime warranty that you can actually grease the ball joints on. You're in my neck of the woods so if you wanted an assist to DIY ping me.
Old May 19, 2020 | 11:42 AM
karls10jk's Avatar
Moog's lifetime warranty extended to one replacement for me, after that they wanted me to purchase another. That's why I upgraded my drag link to 1 ton items.
Old May 25, 2020 | 03:52 PM
Schlieko's Avatar
Currie is a beast. Love mine. I did a Currie drag link too, although I bought them separately. Recommend doing the upgrade. I have 37s too.
Old May 28, 2020 | 06:32 PM
Dirt Hammer's Avatar
I'm a fan of CAVFAB's 1 ton steering kit.
Old May 29, 2020 | 10:36 AM
barongan's Avatar
nice suggest
