Tie rods
Old Dec 6, 2012 | 12:13 PM
FJ Jake's Avatar
Default Tie rods
My stock tie rods on my 2012 JKU seem shot already with only 10k miles on jeep. This due to lift or major pot holes here in RI? Any recommendations for heavy duty aftermarket replacements? I'm guessing warranty won't cover due to lift kit and tires.
Old Dec 6, 2012 | 12:41 PM
suicideking's Avatar
You said tie RODS, there is just one tie rod. Is it the ends that are breaking?
Correct that it won't be covered under warranty if you lifted.
I replaced mine with Synergy tie rod. Not because it wore out though, because I bent it wheeling. Highly recommend Synergy. That thing is bullet proof!
Old Dec 6, 2012 | 12:43 PM
Monte417's Avatar
What is the issue and why do you feel its shot? Just curious
Old Dec 6, 2012 | 12:55 PM
Rob 12B1P's Avatar
Might want to check your ball joints too. Mine are bad at 13K
Old Dec 6, 2012 | 01:12 PM
TheTerminator's Avatar
Yes, go with something like Synergy. It has 1 ton tie rod ends, and the tie rod is 200% stronger than stock. You can bash it against rocks no problem.
Old Dec 6, 2012 | 01:24 PM
FJ Jake's Avatar
It's just the ends, not the rod itself. Will synergy fit stock rod or did you upgrade rod as well?
Not sure what mechanic was saying in detail about them but said they needed replacing.
Old Dec 6, 2012 | 07:19 PM
Smashboogie 4x4's Avatar
Former Vendor
The stock tie rod is garbage. I came down easy on a rock and bent mine and turned my steering stabilizer into a U. I would replace the entire tie rod and not just the ends. If you plan on wheeling or have wheeled at all you probably already have a bent tie rod.
Check out this tie rod. This is what is on my JK and I have put it through its fair share of abuse!
Another good tie rod is the Rock Krawler Tie Rod.
Hope this helps.
Old Dec 6, 2012 | 07:58 PM
Yeah, if you wheel it in rocks, you will very soon bend your stock tie rod, even if you think you are going to be careful. I was trying to be careful here too, when I tried to climb up:
But tires spun and I slipped onto a rock:
And then I bashed it a few more times trying to go up unsuccessfully. The tie rod is still straight:
Moog 1 ton tie rod ends I believe work with stock tie rod, but don't take my word for it. I know with RK tie rod you can use either, so that tells me the thread is the same.
Old Dec 7, 2012 | 05:45 AM
FlameRedJK's Avatar
I use the Rock Krawler HD Tie Rod.
Rock Krawler has a good video on YouTube of them beating it up pretty old and it just bends right back in to place.
It's thick aluminum so it has some give and rebound.
Old Dec 7, 2012 | 06:01 AM
familytime's Avatar
JK Forum Regional Rep
We use Rock Krawler's HD tie rod,yep that's 45lbs of steel,used the ends for the drag link.Got them from jeep.May want to check out the write-up that Eddie did on this swap
