Tire Carrier Delete or can it hold a 35?
Old 08-19-2014, 10:52 AM
  #21
WINGIT's Avatar
Skid Mark Extreme Duty Hitch Skid Plate, 1/4" Steel, Powder Coated Red - SM501RP
Thought about this but it is more $$$$ and takes more of my departure angle away.
Old 08-22-2014, 11:23 PM
  #22
LBZRCKS's Avatar
What about this mount? I ordered this one and I'm putting it on in the next day or two. I've also got a 35 to mount.
| TeraFlex Suspensions
Old 08-23-2014, 12:29 AM
  #23
brian2510's Avatar
Originally Posted by LBZRCKS
What about this mount? I ordered this one and I'm putting it on in the next day or two. I've also got a 35 to mount. | TeraFlex Suspensions
Let me know how the mount works, been eyeing this one to
Old 08-23-2014, 05:29 AM
  #24
JDub23's Avatar
Originally Posted by WINGIT
My cheap fix. Not only does it hold the weight if the tire it also acts like a skid plate. Seen someone almost rip the tire off the back going down a cliff like ridge. Made me think of this. It has taken some hits so it works as planned.
Good idea, actually....
Sent while my wife wasn't looking...
Old 08-23-2014, 09:37 AM
  #25
stuozzy's Avatar
Originally Posted by Dahmer
I ran a 35-12.50-18 on the stock carrier for over a year until I got a tire carrier. The main problem is with the welded nuts in the tailgate coming out. I replaced mine with the MBRP kit, think it's like $25. The other issue is with the tire bouncing around from the rubber isolators being to short. Daystar make an extended version that will stop that. Only problem that isn't addressed is the extra wear on the tailgate hinge. To minimize this don't open the tailgate unless you have to and don't leave it open for extended periods. This isn't the best solution but it works. I never at any point even when off-roading heard or saw the tire move much or act like it was straining the tailgate.
I run this exact setup and have had zero issues with over 50k miles on my jeep
Old 08-23-2014, 12:20 PM
  #26
oletennessean's Avatar
fullmetalfabworks.com
Old 09-01-2014, 05:18 PM
  #27
LBZRCKS's Avatar
Here's the mount installed.
It was really easy to put on. I used a press to push the studs through the mount. If you run a wheel that uses caps that cover the lugs, you won't be able to run the cap on the spare with the 3rd brake light relocated as it uses the top 2 lugs to mount the bracket.
ID:	574018Click image for larger version
Old 09-05-2014, 02:59 PM
  #28
RedSyndrome's Avatar
Originally Posted by TakeABackRoad
What have you done for a rear tire carrier delete? Curious to see people setups and it you relocated the 3rd brake light and license plate. I'm assuming that my stock carrier can't safely hold a 35. Can't afford a tire carrier right now so was going throw the spare in the back. Just wondering what options I had.
If you want to carry it inside...I was looking at one of the big drawers from Smittybilt or Mac's Black Box. Then mount a pre-runner style angled bed mount tire carrier on top of it. You may have to re-inforce the lid a little. That way you have the storage in the drawer and the spare inside.
The stock carrier seems more than strong enough to carry the 35's. I have been for a while. I had to get Daystar extended tailgate bumpers. They keep the tire from shaking and pulling out the bolts.
Old 09-05-2014, 04:28 PM
  #29
20jk08's Avatar
Default re:
I carry my spare in the back, 35 just fits, made a ghetto looking box to hold a few things, still have to figure what I want to do with the 3rd brake light.
Old 09-05-2014, 05:22 PM
  #30
Robb3369's Avatar
I would move the light to the top of the box... Or an led strip across the edge.
Quick Reply: Tire Carrier Delete or can it hold a 35?
