Tire carrier question. Is tire physically secure?
Old Apr 28, 2013 | 07:09 AM
gnarlyswine's Avatar
Default Tire carrier question. Is tire physically secure?
I'm running a modified aftermarket carrier. Because of backspace issues the tire is actually held by the rubber against the carrier frame. And three lug nuts hold the tire on. Because there isn't metal to metal contact this way I can't get the nuts tightened well, and there is a fair bit of deformity where the tire contacts the carrier.
So two questions really.
Are the bolts likely to work loose? Should I see if I can find a spacer?
Will the long term deformity damage my sidewall?
Thanks
sent from my difference engine using tapatalk
Old Apr 28, 2013 | 07:20 AM
LidLess07X's Avatar
Thanks
Cut the rubber to get it closer or buy a wheel spacer
Old Apr 28, 2013 | 07:36 AM
slider_68's Avatar
I think he means tire rubber not bump stop rubber...cheapest way would be to add a stack of washers to each stud behind the wheel until the tire just kisses the carriers frame, snug but not deformed. Then either leave it be or find a spacer the thickness of the washer stack
Old Apr 28, 2013 | 08:46 AM
Yes that's right. I do mean the tire. I'm on the lookout for a single spacer but that washer idea is a good one. I'll still be a bit worried about the bolts shearing but that sounds at least a bit better.
Thanks
Old Apr 28, 2013 | 08:48 AM
Mark73's Avatar
Thanks
Cut some pipe into spacers
