tire difference question
Old Feb 7, 2011 | 12:53 PM
BigBallin's Avatar
Default tire difference question
so what the difference between a 35.12.5x17 and a 295x70x17? besides that the 35x12.5 is a true 35 and the 295 is 34.5. there is about a 50$ difference per tire
Old Feb 7, 2011 | 01:01 PM
RevyJKU08's Avatar
actually the 295/70R17 is a approx. 33.5" diameter and 11.6" wide.
35x12.50R17 is not always a true 35" check the specs of the tire manufacture & brand you are looking at to get the true specs. Most 35's are about 34.5 to 34.8" diameter but the width is usually very close to the 12.5" wide.
nthinuf's Avatar
Search on the specific tires you are looking at to see what the 'actual' heights are. That 'true' 35 is probably 33.5-34" tall. My old 295/75's were 32" even. Also look at the load rating. There will be a noticeable difference between a C and an E.
Old Feb 7, 2011 | 01:03 PM
mattgt5's Avatar
295-70-17 is a 33-11.50-17. Always look on the specs section of the tire for the section width and overall diameter. Every manufacturer's definition of "35" is different.
Old Feb 7, 2011 | 01:04 PM
mattgt5's Avatar
wow, we all jumped on taht one at once. Should not be much mystery to the answer after those three posts
Old Feb 7, 2011 | 02:23 PM
BigBallin's Avatar
im looking at the nitto trail grapplers. the 295s are 250 a piece but the 35x12.5 are 320 a piece
Old Feb 7, 2011 | 02:28 PM
adrom's Avatar
im on the 295's for 70 bucks, it was an easy decision
Old Feb 7, 2011 | 02:34 PM
nthinuf's Avatar
How about starting with the MFG's website?
35x12.50x17 = 34.84 x 13.19
295/70/17 = 33.54 x 11.97
So from looking at the specs that the MFG lists, maybe you can start to understand the price difference? Then you will want to do a search on each of those tires to see what 'actual' heights people are getting with them mounted and under their JK's.
Old Feb 7, 2011 | 02:48 PM
BigBallin's Avatar
thats what im thinking
