tire dilemma
Old Nov 14, 2012 | 03:42 PM
nicktech's Avatar
Default tire dilemma
Ok, so i have a brand new 2012 JK 4-door Sahara.
I am planning on throwing on a RC 2.5" BB, 35" tires and new wheels with 4.5" backspacing
I know it will fit and some actually run with no lift.
The dilemma...
I have the possibility to get 37" MTR/Kevlar with nice wheels (4.5" backspacing) locally.
The tires have about 6000 miles on them and measure 36" when on vehicle and wheels are mint
Will they fit ok for purely street use with the 2.5" BB?
Anything else I should consider?
Again this Jeep will not see any wheeling so articulation is of no concern
I appreciate your comments
Old Nov 14, 2012 | 03:51 PM
conifers4's Avatar
It would be a squeeze for sure. At the very least you would have to trim the pinch seams.
Old Nov 14, 2012 | 04:25 PM
nicktech's Avatar
yeah i think the pinch seam would have been an issue with 35's as well
Thanks
Old Nov 14, 2012 | 04:27 PM
Ryan0260's Avatar
It won't look good. I would at least cut the fenders
Old Nov 14, 2012 | 06:18 PM
Wandell's Avatar
Loved
You could also throw on a body lift if you want the 37's. But you will also want to regear with 37's, which is a major expense.
Old Nov 14, 2012 | 09:03 PM
suicideking's Avatar
Don't do it! Even 35's on a 2.5" lift can be pushing it. 3.5 - 4" of lift is ideal for 37's, not 2.5".
As mentioned above, you would definitely need flat or chopped fenders. You'll also want to re-gear, gas mileage will be worse.
Old Nov 15, 2012 | 09:22 AM
OR-FAB's Avatar
Sponsoring Manufacturer
OR-FAB
x2 on both points. A 1" or 2" Performance Accessories body lift would be an inexpensive way to make room for the 37"s and would def. need to regear.
Old Nov 15, 2012 | 12:17 PM
nicktech's Avatar
I presently have 3.73 gears...it's a 2012 auto
I didn't think there would have been such a difference between 35's and 37's
Old Nov 15, 2012 | 12:31 PM
35's are considered borderline for the '12 with 3.73. 37's and you're probably going to want gears. It would be comparable to 35's on 3.21.
It might be livable. You could always try it and decide later. However, a good price on gears + labor will run $1000.
Old Nov 15, 2012 | 01:37 PM
TheTerminator's Avatar
I think front and rear bumpers will rub as well. Inner plastics in the rear will definitely rub, going over bumps.
