Tire Help
Old Jun 24, 2013 | 06:38 AM
pingman77's Avatar
Default Tire Help
So im really liking my first jeep (2013 automatic jku oscar mike). I just want bigger tires. My gears 3.21 are my hold back. How foolish am I to get some trail grapplers in 295/70/17 or 285/75/17. I was thinking at, but I love the mud tire aggressive profile. The 295 is roughly 33.3 and 285 is 34. Would one be better than other in regards to my gearing?
Old Jun 24, 2013 | 06:41 AM
kh202's Avatar
Auto isn't ideal when you're undergeared but I think you will be just fine. I'm running 35's on my 3.21's
Sirtreysif's Avatar
Depends on what you intend to do, where you intend to drive. If your 100% highway flat ground shouldn't be a problem. If your goin to do some wheelin I would stay as close to the 33s as possible.
Old Jun 24, 2013 | 06:42 AM
Sirtreysif's Avatar
Alot of time with o/d off lol. I'm running 35's with 3.73s and that's step #1 when going anywhere.
Old Jun 24, 2013 | 07:48 AM
pingman77's Avatar
Mostly around town driving. I do a couple interstate trips a month. Im leaning toward 295 trail grappler. Its smaller diameter but weighs more than the 285 trail grap. For someone like myself with 3.21 gears, whats the best route? A larger diameter tire that weighs less or smaller diameter weighing more?
Old Jun 24, 2013 | 08:28 AM
JK Inspired's Avatar
You're putting the cart before the horse, IMO. Deciding what tire is "horse." Do you need the additional 1/2 inch height or do you want the 1/3 inch in width? Drive the choice in tire on the 3.21s and THEN decide how much RPMs you want to get back by deciding on the R and P
Old Jun 24, 2013 | 08:58 AM
mattgt5's Avatar
Think weight over diameter. It's the force required to roll the mass. More mass, more force. Do the lighter, especially if its taller.
Old Jun 24, 2013 | 09:40 AM
pingman77's Avatar
I dont need anything. Its a matter of my opinion. In my opinion, my current tire size look like mounted doughnuts. Im just hoping for personal experience on how big I can go and it be manageable. If its going to cause transmission harm or other failures, I will have to live with current setup.
Old Jun 24, 2013 | 09:51 AM
CSJK77's Avatar
Agreed with the weight issue.
The Nitto website has weight info, but I know (remember when I was looking for tires) both those tires are fairly light compared to 33/12.5 and 35/12.5 because they don't have the width. That's what I was going to go with but found a good deal on MT Baja MTZ that I could not pass up.
Old Jun 24, 2013 | 02:19 PM
Ryan0260's Avatar
Make sure to get a tuner or pro cal to calibrate the tire size which will correct the shift points. It should be liveable to drive.
