Tire help please!!!
Old Dec 18, 2011 | 02:45 PM
areeves65's Avatar
Default Tire help please!!!
Newbie here.... I would like to know if these wheels and tires would fit on my stock 2008 jk Sahara unlimited?
Wheels
18x9 wheel size
5x5 bolt pattern
4.5" backspacing
load lbs. 2200
-12mm offset
Tires
285/60R-18
Load range XL
overall diameter 31.4"
Old Dec 18, 2011 | 03:13 PM
dcharge74's Avatar
Yes, they'll fit. You should even be able to get away with the stock wheels. They are 1/2" shorter than what you have on there now, and about an inch wider. But the extra width will be split to both sides of the wheel. 1/2" on both sides.
Old Dec 18, 2011 | 03:18 PM
areeves65's Avatar
Thank you!!!
Old Dec 18, 2011 | 04:00 PM
areeves65's Avatar
Will it affect my speedo or make my jeep lag at all?
Old Dec 19, 2011 | 08:57 AM
areeves65's Avatar
Can anyone answer my last question please and thank you!
Old Dec 19, 2011 | 09:40 AM
2BAJeep's Avatar
Assuming your stock tires are 32 and you are going to 33s I would say your speedo will be off but very little. maybe 2 mph... as for lag, should not be much, if you are not running a tuner you may want to... that will readjust your speedo and give some performance back...
Old Dec 19, 2011 | 10:56 AM
areeves65's Avatar
Thank you. That helps a lot
