tire lifespan ??????
Old Jul 12, 2010 | 09:39 PM
fitzb's Avatar
Default tire lifespan ??????
Alright, whats the deal-- I rotate my tires every 4-5000 miles and already notice wear. I'm running Toyo open country m/t and was told to expect about 40,000 miles. I just hit 11,000 and can see noticeable wear. Is this normal???
Old Jul 13, 2010 | 03:22 AM
Alec's Avatar
Is the wear even, or do you have a possible alignment or other issue?
But think about it, you're 25% into the stated lifespan. That amount of wear would be noticeable but they should have plenty of meat left.
I have ProComp Xtreme AT's which should also last 40k, with 16k on them, and I started to notice wear around 12k.
Old Jul 13, 2010 | 08:42 AM
rubicon07's Avatar
I have a set of 35'' toyo's. i just hit around 20k on them, and just got some noticable wear..What pressure do you run...i know these tires get 40K + ...
Old Jul 13, 2010 | 08:54 AM
Converted's Avatar
"Noticable" is a pretty subjective term. I would suggest measuring each tire just inside the shoulder lugs and in the center of the tread pattern, Compare that to the as new condition and a little math will give you a pretty good estimate of how many miles you should get out of them assuming 3 or 4... or 5 or 6/32 as the end of life depending on your use.
Old Jul 13, 2010 | 11:50 AM
rubicon07's Avatar
noticable?.. for us who have high quality set of M/T tires ie(toyo's). You know just by looking at them.
Old Jul 13, 2010 | 11:53 AM
Pluke the 2's Avatar
Subjective term: Show some pictures
Old Jul 13, 2010 | 09:14 PM
fitzb's Avatar
wear is pretty even, no alignment issues. I will get pics up soon. Thanks for the input guys
