tire and lift advice
i have an 2008 4dr JK and its time to give it a new look ... i am looking to put 18" rockstar rims or something similar and either 33 or 35 tires... however i am looking to use the 2.5 terflex coil lift and wanted to get some input on what size tires i can fit with that lift???or other recommendations??... i so some trail riding but nothing to crazy... i want it to look good and be functional in all driving conditions... just looking for some advise and input ...thx
You will be able to fit 35's with the 2.5" TF, and for the rims, make sure the back spacing is 4.5 or you will need to run wheel spacers. I would suggest 16" or 17" rims if your going to be wheeling. It's mostly preference but I know most will say wheeling is best with 17" or under. Plus, you will have ALOT more options for tires going with 16"-17" rims and MUCH cheaper.... I think the the TF coil lift is a good choice... Are you getting it with or without the shocks ?
i am looking to install the exact same thing soon. rockstars and 35s as well. How much should the labor cost to install the 2.5 tf coil lift with new shocks? i dont want some scumbag ripping me off and i def wont be installing on my own
I wasnt sure if i should do the kit with or without shocks ?? i have low miles and light abuse on my stock shocks? i was told if i run a 35 i should regear my rear end ,,, any input??
