tire pressure
Old Jul 16, 2010 | 02:37 AM
zeprep's Avatar
Default tire pressure
Any advise on tire pressure on a 2009 Sahara running 33 x 12.50 x 17 m\t baja mtz w\2in OME lift for on road, off road
Old Jul 16, 2010 | 03:22 AM
GON WHLN's Avatar
onroad: 30-35psi experiment for which rides the best
offroad: 10-20psi depending on cargo and load
Old Jul 16, 2010 | 11:31 AM
nthinuf's Avatar
Lots of good info in the FAQ's...
Q: On the road, what PSI should I be running in my tires?
A: For optimal comfort and even tire wear. you should not run the recommended PSI listed on the sidewalls of your tires. Typically this will be way too much. On average for a 33" tire, I would recommend that you run your tires at approximately 28-30 PSI. For a 35" tire, I would recommend running approximately 26-28 PSI. For a 37" tire, I would recommend approximately 24-26 PSI.
Q: On the trail, how much should I air my tires down to?
A: Typically, I recommend that people air the tires down to about 10~15 psi.
