tire pressure sensors
Old Mar 30, 2009 | 07:17 AM
Bigshow's Avatar
Default tire pressure sensors
I just purchased a lift and some new wheels and tires. I currently am stock and have my tire pressure around 33-35psi with the new tires i am told is a max or 50psi should i even bother adding the tire sensors back will they work? and lastly should i be looking to run the tires with nitrogen. Also what does nitrogen do other than adding no moister. I live in NJ and not too many rocks to crawl on?
Old Mar 30, 2009 | 07:36 AM
White Widow's Avatar
your tpms will work and doesnt hurt if not reinstalled, you will just have to deal with the little light. 50 psi will be a rough ride. if i remember correctly my max psi for my 37 iroks is 70 psi i run them around 30-32 on the road and 7-8 on the trail. i reinstalled mine but broke them all off while wheelin. nitrogen will not expand and contract in different temps. this will ensure your tire pressure will remain the same unless you have sprung a leak
