tire question
ABOUT TIRESIZER
TireSizer is a tire size calculator and provides other useful information about your vehicle's tires and wheels.
TireSizer quickly calculates the height of your vehicle's tires and axles when you want to replace your tires or rims with wider or narrower sizes, or taller or shorter sizes to raise or lower your vehicle.
It uses your passenger or light truck tire size data such as P237/75/R15 (tread width, aspect ratio and rim diameter).
TireSizer also works with flotation truck tire sizes such as 31x10.5R16, high flotation agricultural tires 66x44.00-25, high flotation forestry tires 68x70.00-32, and large P-metric flotation tires 700/55-34 and 850/50-30.
Right now I have 70's and I would like to know
Is there a chart or app that will convert the metric tire ratings to standard?
Or go to the website of any tire maker/retailer. They will all list the standard dimensions for their metric tires.
For the rim width, every manufacturer will list the recommended width for all of their tires. If you want to go out side of that window, talk to your installer to make sure that they will mount them for you. Some will, some won't. (I think a 13.5" width on a stock rim is the widest I have seen posted)
