Tire question??
Old Jun 25, 2013 | 06:51 AM
Temple333's Avatar
Default Tire question??
I was wondering about tire pressure for 35s to get a even wear on them ... Right now I'm running 40psi should I be running lower or higher ???
Old Jun 25, 2013 | 07:06 AM
kh202's Avatar
What size wheel/ width are you running and what kind of tire? In general, 30 psi is a good number, but ideal for your particular set up could be +/- 5 psi.
Yellowfin's Avatar
Depends on the weight of your rig including all the add-ons, but usually, 30psi is about right. That's what I run on my 37's and it wears great across the tread pattern.
Old Jun 25, 2013 | 07:35 AM
Ryan0260's Avatar
There are many factors in determining this. Vehicle weight, wheel width and tire load rating are the main ones, and doing a chalk test is the best way to find out the exact amount of pressure you should be using for your setup. As mentioned, 30 psi is a great starting point.
Old Jun 29, 2013 | 08:42 AM
Da Q's Avatar
I agree. I have a heavy rig and the tire rating says 50lbs cold pressure. I did the chalk test and run with 30lbs...tires run even wear.
