Tire Question
Old Apr 24, 2008 | 12:01 PM
derekls's Avatar
Default Tire Question
Ok so right now I have 265 75 16 A/T's
I have a chance to go up to 305 70 16 M/T (firestone dest mt)
My question is will they fit alright(no rub and not strain my axles/drivetrain to much?
I have the OME lift
I also have the X ...which would be 30 up front and 44 out back
3.21 gears 6 spd)
Old Apr 24, 2008 | 12:13 PM
derekls's Avatar
oh ya the at's are load C and the MT are load E would that make a big difference as well?
Old Apr 24, 2008 | 12:16 PM
sasquatchpoacher's Avatar
C rated tire will ride better. E rated is for heavy trucks and what not. That being said a lot of people ride D and E rated tires on their JKs and don't mind the extra stiffness of the tire.
Old Apr 24, 2008 | 12:24 PM
derekls's Avatar
I dont think I would mind the ride stiffness, i just dont wanna strain my jeep by putting to big a tires for my set up
Old Apr 24, 2008 | 01:08 PM
RedneckJeep's Avatar
How much height difference is there between the two? I would be worried about what effect the taller tire would have on power. Specially with them 3.21s.
Old Apr 24, 2008 | 01:53 PM
chucktuna's Avatar
Great tire sizer thingie:
http://www.miata.net/garage/tirecalc.html
chuck
Old Apr 24, 2008 | 02:56 PM
derekls's Avatar
according to that calc, there is a 1 inch difference in the two sizes....... right now I am close to 32's ...and the new size would be roughly 33's
Old Apr 24, 2008 | 03:09 PM
TEEJ's Avatar
Talking
You'd have a hard time telling the difference for a 1" tire diameter swap.
32/33 = a 3% difference in effective gearing.
So, for example, if cruising at at a given speed on your 32's...if at the same speed on 33's, the rpm would drop by 3%.
If cruising at ~ 2,100 rpm, a 3% drop = ~ 2,037 RPM
That's a 63 rpm difference...shifting down, to simulate getting lower gears for example, would drop you by more like 500 rpm or so, etc..
So, as its such a tiny difference in both axle strain and effective gearing, (~3%) its not worth worrying about.
Old Apr 24, 2008 | 03:14 PM
Well I have 245s and 3.73s and am kinda skiddish of 33s.
