Tire/rim help on 2dr '07 Base X
Old Jul 30, 2007 | 08:52 AM
tksJK's Avatar
Default Tire/rim help on 2dr '07 Base X
Hi all, I am going to order new tires and rims for my daily driver 2dr 2007 Base X with no lift. I was wondering if I would have any rubbing issues running Cragar chrome soft 8 17x9 with MT Baja Radial MTX 32x10.5r17, or if i am better off going with a 16x8 rim instead? or is anyone currently running this setup? Thanks for all the help in advance.
Old Aug 1, 2007 | 06:47 AM
BlackJett's Avatar
Hey tks,
I'm running a similar setup you want. I have the X also. I have the ProComps in 17x9 with those same tires. No lift on it (yet) but the SuperLift BB is on the work bench in the garage itching to go on.
I have no issues at all; none. I commute daily, and the only difference is I have a bigger smile when I'm around our JK with the new tires and wheels.
Go For It.
Have a great day.
Old Aug 2, 2007 | 04:34 AM
tksJK's Avatar
Thanks BlackJett for the info, that was exactally what i was looking for.....I was thinking about a lift as well, but in a few months. Good luck with yours!
Old Aug 2, 2007 | 04:58 AM
Here's RedRock's tire calculator, if it helps:
http://www.redrock4x4.com/tech/tire_calc.php
I don't think you would have a problem, that's not much larger than the upgraded wheels/tires (245/75-16); about 1.5" taller and .9" wider.
Old Aug 2, 2007 | 05:59 AM
tksJK's Avatar
Thanks for the link C_Kyle
