tire/rim width question
Old Jan 21, 2008 | 07:48 AM
barbourjay's Avatar
Originally Posted by Nozz
the narrower the wheel the better for airing down. acts like a bead lock but I have heard to narrow a wheel will balloon the center causing premature tread wear. some people air down to flatten that out but now we still run into the tread life and gas mileage problem
so will the 15X10 with a 4inch BS work fine or will it rub?
Old Jan 21, 2008 | 04:00 PM
Nozz's Avatar
Should be fine with 3" lift for 35's 2" for 33's. 10" wheels will make your tires look wider as well.
Old Jan 21, 2008 | 07:08 PM
barbourjay's Avatar
and if i don't want to lift it yet? i only want to run 33X12.5's at this point. i'm just trying to make sure the 15X10's will clear the calipers with a 4inch backspace.
Old Jan 22, 2008 | 03:44 AM
barbourjay's Avatar
top for the morning.
Old Jan 22, 2008 | 04:07 AM
red rcok's Avatar
and does the backspacing required change depending on the radius
Old Jan 22, 2008 | 05:22 AM
barbourjay's Avatar
think i found my own answer, here is someone running the setup but with 35's instead of 33's.
https://www.jk-forum.com/forums/modified-jk-tech-2/will-rubi-sliders-hit-my-35s-rear-26030/
