tire rod
Old Apr 9, 2009 | 10:40 AM
Bigshow's Avatar
Default tire rod
What is the difference between a sealed axle and a tire rod
Old Apr 9, 2009 | 10:45 AM
Robar's Avatar
A tie rod connects the front wheels, so they turn at the same time. The axle assembly contains the gears and axles that turn the wheels.
Old Apr 9, 2009 | 11:17 AM
Bigshow's Avatar
EVO 44 Magnum Sealed JK Axle Sleeves would replace the tire rod correct with welded gossets
Old Apr 9, 2009 | 12:05 PM
leros's Avatar
an axle sleeve wont replace the tierod
Old Apr 9, 2009 | 01:33 PM
roguejk's Avatar
nothing replaces a tie-rod...they are two seperate pieces!
Old Apr 9, 2009 | 07:08 PM
nangulator's Avatar
Somebody needs to take a goooood look at that pic up top
Old Apr 9, 2009 | 07:11 PM
tkob1060's Avatar
From: Hangin in the sunshine state....staging forum..
Old Apr 9, 2009 | 07:17 PM
a TIE rod upgrade would replace the TIE rod with a stronger one. those evo magnum sleeves strengthen the axle by 30% (at least thats what they say) so the tube does not bend.
Old Apr 9, 2009 | 09:24 PM
Hellbound13's Avatar
Ahh the tire rod. You know, the rod that connects the tire to the hamster on the wheel. Yeah, you def want to upgrade that part.
Old Apr 10, 2009 | 03:20 AM
greenamphibious's Avatar
a tire rod
Tire rods rust easier
