Tire Rotation
Old May 26, 2011 | 04:44 AM
Mark Doiron's Avatar
It will not damage the tires--that may have been true decades ago, but no longer. Here's a novel idea: Follow the rotation diagram in your owners manual. :-)
Originally Posted by IXPLORN
Thanks for your novel suggestion, you're such a smart . . .
Sorry, I wasn't clear. This owner's manual:
tirerack.com/images/pdf/warranty/GYEAR1.pdf
Unfortunately, it says to contact the vehicle manufacturer or Goodyear for the rotation pattern.
Old May 26, 2011 | 05:02 AM
IcyFridge's Avatar
For mud terrains, rotate every 4000. For all terrains, every 6000.
Assuming tires are not directional....
Front tires switch sides and go back. the rear tires go straight to the front on the same side.
And noise/vibration is normally louder after a rotation for a little while, since the tires are not running on worn tread anymore. They are now getting "rounded out" again due to them being in a different location.
Old May 26, 2011 | 06:04 AM
Dex1's Avatar
I dont run on the Goodyears, but, as a rule, on all my 4x4 trucks with other than stock tires, I have always rotated at every oil change (3000-3500 mi.) and have never had any major issues!
Old May 26, 2011 | 08:56 AM
MDJKER's Avatar
With the rotation pattern suggested above, how are you guys rotating in your spares (if you're doing it at all)? I never have but am considering it. My guess is that it shouldn't really matter which tire you rotate out as long as it's always from the same position. does this sound logical?
Old May 26, 2011 | 09:02 AM
IcyFridge's Avatar
This JK is my first with the spare tire thing. But right now it is mismatching so I don't include it lol.
When I go up to 35s, I will slap on an old worn 35 on my stock rim for a spare when needed.
Old May 26, 2011 | 11:02 AM
Seir's Avatar
I do what they call a rearward cross.
Old May 26, 2011 | 11:06 AM
HappyCurmudgeon's Avatar
Eternal ***erator
X2 same pattern. 35k on my STT's with no issues.
landoJEEP's Avatar
so anyone running 35's have input on rotating in the spare? seems to me since my Toyo that hasn't hit the ground cost a lot.. I should rotate it in to get some use out of it.
has anyone done this for the whole life of a M/T tire and have feedback on if it extends the mileage you got out of 'em?
Old May 26, 2011 | 12:46 PM
Seir's Avatar
Can't speak to the specifics of 35's but I do it because based on the numbers alone; they tell me I will extend the life of my tires by 20% by rotating in the spare. Plus, near the end of my tires life, I wouldn't want a spare with 100% tread as that would seem to be very imbalanced if I ever had to put it to use.
Old May 26, 2011 | 12:49 PM
landoJEEP's Avatar
Excellent point. think i'll be using mine when it's rotate time.
