Tire rub-FYI
Old Aug 6, 2013 | 12:47 AM
JK Inspired's Avatar
Originally Posted by cpd806
I put 275 70 R18 Goodyear Duratracs on my 12 JKU and was grinding at the air dam but only in reverse with steering wheel to full left going down a small divot in my driveway. 1.5 spacers and one inch coil spacers are also on the rig. I read a ton on this before I bought the tires and everyone said that there would be no rubbing issues with either wheel spacers or 1 inch coil spacers. I did both. Just a fyi. Now to shave the air dam down some.
People are missing the reason for the post.
Old Aug 6, 2013 | 03:38 AM
kh202's Avatar
What's that? That the air dam is highly removable to clear wider tires?
Old Aug 6, 2013 | 06:17 AM
To answer the second question- no. To address the first, read thee original post.
Old Aug 6, 2013 | 06:45 AM
kh202's Avatar
His tires rub but "only in reverse with steering wheel to full left going down a small divot in my driveway"????? Got it
Old Aug 6, 2013 | 06:58 AM
Ryan0260's Avatar
This is it^^^
Old Aug 6, 2013 | 07:03 AM
Nope.
He said,
"I read a ton on this before I bought the tires and EVERYONE SAID that there would be no rubbing issues with either wheel spacers or 1 inch coil spacers. I did both. Just a fyi."
Got it?!
Old Aug 6, 2013 | 07:06 AM
kh202's Avatar
Nope.
He said,
Got it?!
Break out the lawyers?? Lol don't know what to say man. It's a piece of 1/8" plastic with no purpose. Don't see the issue. OP sounded like he had the situation under control by trimming it.
Old Aug 6, 2013 | 07:12 AM
Ryan0260's Avatar
Actually, I used my air dam as a dust pan before I threw it away when I was cleaning the garage. But to the OP, while removing it looks better, trimming it will work fine, and does slightly reduce hood flutter at highway speeds.
Old Aug 6, 2013 | 07:14 AM
Jonathan_JK's Avatar
You can trim it with a cutoff wheel. Get a wheel with more backspacing. Or you can do what most of us have done and just 86 the thing and then your rubbing issues are taken care of.
Old Aug 6, 2013 | 07:16 AM
^^^ dam I wish I would have thought of the dustpan idea....
I took mine to the junkyard and got $20
