Tire size
Old May 15, 2007 | 06:49 AM
Fletch's Avatar
Default Tire size
Using the stock rims that came with my 2007 JK-X, what is the widest tire I can go with without using spacers or a lift kit. I would like to go to a 32-33" tire, maybe just a 32 for now. Thanks for any help!!!
Old May 15, 2007 | 06:54 AM
Txhrns08's Avatar
i am not sure but i would bet now more that a 11 or a 11.5 You might be able to get a 33x11.50x 17 or 16 and be ok
Old May 15, 2007 | 07:26 AM
Jeep School's Avatar
We tried to put 33x10.50's on stock wheels and had serious rubbing. Even 255 rubbed. We went with the 1-inch spacers on the X's to get 10.50 wide.
Old May 15, 2007 | 08:26 AM
armycop's Avatar
I had no problem with a 265/75/R16 on a stock 16" alloy rim before the lift. It still sits about 1/2 inch inside the flares no rubbing at all.
Old May 15, 2007 | 08:50 AM
Chipster's Avatar
I just put 275 70 17s on my stock wheels and it fills it up nice.
they are 32.4" tall, i did add a 1" spacer because i like the wider stance.
Old May 15, 2007 | 09:22 AM
Dante's Avatar
I have 255/85R16 (33.3 x 10.3) on my stock AL X rims. The only rubbing I get is at full lock on the curve of my sway bar when it is disconnected and the sway bar is pulled up as high as it can go. I have had no rubbing anywhere else.
Old Aug 22, 2007 | 01:40 PM
Rustler211's Avatar
Originally Posted by Houdini
I just put on a set of 285/70/R17 BF Goodrich All Terrain TA KM's (33's) on my Unlimited X. I have no lift or spacers and I have no rubbing that I can tell or hear.
I am thinking about doing the same tires with no lift. Do you have any pictures?
