tire size conversion
Old Feb 3, 2009 | 03:53 PM
boodro7's Avatar
Default tire size conversion
What size does 305/70/17 convert to(including width). If I were to put this size would I need to go with 1.5" spacers? If I wanted to go with an aftermarket wheel would I stick out to far?
Old Feb 3, 2009 | 04:11 PM
tambil68's Avatar
Tires converstion equation..PXXX/YYRZZ equals (((XXX/25.6)*0.YY)*2)+ZZ
eg, p255/75R17 = (255/25.6)*.75)*2)+17=31.94
For anyone reading this thread... here is the formula to figure it out.
Old Feb 3, 2009 | 04:59 PM
BlackNorthernJK's Avatar
Your question is a little all over the place, are you planning on mounting them on your stock rims?...if so then yes wheel spacers will be required, Or are you planning on buying a different rim? Either way of course being a wider tire they will stick out a little, whats too far for you?
Your on a computer, a simple google search will yield many answers for you.
Old Feb 3, 2009 | 05:52 PM
boodro7's Avatar
sorry for the confusion. Thanks for the advise.
