Tire size impact odometer reading?
Old Oct 1, 2011 | 10:25 PM
merlinn's Avatar
AEV should have the updates for the 2012 by the middle of October, I will order one then.
Thanks,
Merlinn
Old Oct 2, 2011 | 12:58 PM
armycop's Avatar
I think that statement was more geared toward the automatic trans. The larger tire size will confuse the shifting and it will hunt for gears because of the perceived slower speed. I don't think there is any performance gain or that the Procal does anything with the engine tuning. The sluggishness you may be feeling can come from the much higher rotational weight of new rims/tires. A small difference in tires/wheels weight takes a lot more power/torque to spin especially if you have 3.21's.
Old Oct 2, 2011 | 04:41 PM
f2fast4u's Avatar
Originally Posted by jeepmojo
will correct the ecu and poor performance due to installing lager tires isnt that tuning????? to a degree or is this false statement on thier part ? if what thier saying is it corrects poor performance due to larger tires , means that the readings arnt performing correct its kind of misleading to mention ecu !!!! any thoughts on this ?? read what it says correct me if im wrong ? i note my 2011 runs kinda funny after adding 285/70/16s it seems to flood out a little on takeoffs and reverse it would stand to reason if ecu thinks it has 29 inch tires on it and i have 32 inch tires the jeep dosent know how much fuel to send to get it to move !! wich im wondering if this is what thier talking about ! mine seems to want to stall a lot on take offs ! sometimes i feel like i almost have to ride the clutch a bit just so it wont stall and then im taking off faster than what i intended , this needs to be adressed on mine also ! wonder why this happens ? any advise is good advise at this point , thanks
My two cents - most highly complex computer applications have preloaded tables with values in them. You do this so that making changes to those variables doesn't require actually modifiying written code. I'd guess that the AEV Procal merely give one the ability to change those table values. But those table values have nothing to do with changing logic in the system. That's a whole different ball game. For my Mustangs, I actually have a setup to literally change the Ford computer logic for the Fox body models. Oh yes, you can destroy the earth with that (right along with the engine as well).
Old Nov 30, 2011 | 03:04 PM
cloddhopper's Avatar
Originally Posted by armycop
Yup plus its giving you a false (lower) mpg because of the odometer being off by 10-15%
It only took me a full day to find this quote. Thank you. One extra question, will the pro cal leave a "footprint" on the ECU? I don't want to have any warranty issues on my 12'. Thanks
Old Nov 30, 2011 | 03:07 PM
anarch's Avatar
Default Speedometer re-programmer
Just put one of these on a 2012 that was lifted... easy to do, doesnt mess with engine warranty ( like all other programmers that include performance options)
http://www.hypertech.com/products-results.aspx
part # 752001
