tire sizes
Old Sep 7, 2009 | 01:15 PM
wranglerxnewbie's Avatar
Default tire sizes
Hello,
I am looking to replace my tires to larger ones. i just did a 2.5'' coil spacer lift, and have put 1.5'' spacers to widen the stance. I am just wondering the largest tires i can put on my stock 17'' rims without any rubbing.
right now i have 255/75/17, and they are too small.
please help
thank you
Old Sep 7, 2009 | 01:36 PM
Bacon's Avatar
first of all, welcome to the forum!
second, this thread should probably be moved to the modified section, which I'm sure will happen once a mod sees it,
third, and to actually answer your question, there are a lot of ppl running 35" tires with the exact setup you have. i think there may be some very slight rubbing at full flex with the wheels turned off road, but on road there is no rubbing at all.
Old Sep 8, 2009 | 12:47 PM
whyhike's Avatar
i guess he could squeeze in here because he's looking to use his 'stock' wheels.
Old Sep 8, 2009 | 04:09 PM
nthinuf's Avatar
Start in the Wheels and Tires area of the FAQ - (stickied at the top of the Modified section)
Old Dec 1, 2009 | 06:15 AM
RyanBlack321's Avatar
I had 33s on my 2d i had with a 2" lift with plenty of room left over
