Tire Warning Light...
Old Oct 26, 2012 | 02:46 AM
16 Unlimited Ways's Avatar
Default Tire Warning Light...
Guys i put back on for winter rims & tires...They have TPMS installed on factory JK wheels
with BFG's MT tires (Rubicon)...I recalibrated with AEV Procal for the smaller tires light still
comes on in the dash...What's next...
Old Oct 26, 2012 | 03:00 AM
leftcoastpunk's Avatar
Black electrical tape on the lucite between your eyes and the annoying thing? Works for me.
Old Oct 26, 2012 | 03:02 AM
a4x4high's Avatar
Make sure tire pressures are what it says in the door they should be then drive it if the light doesnt go off you will have to go to the dealer and have it reset. If the light is flashing before it comes on solid you probably have a bad sensor. Or ignore it and use the tape ideal.
Old Oct 26, 2012 | 04:59 AM
SCHLEPPN02's Avatar
Did you also calibrate the Procal to look for a different psi? (if there is a difference in the range you ran on previous tires?) There are setting for both overall diameter and psi range with the AEV.
Old Oct 26, 2012 | 05:29 AM
snytribe's Avatar
I just went through this problem when I lowered the psi on my tires. Got this answer from someone on the forum and it worked. Set the pro cal for what psi u want to run. Put in at least 5 psi in the tires over what you set the pro cal for. Drive like that for a day and then set the psi in the tires were you wanted them. The answer I got was second hand and he remembered something about doing that to reset the tps. It worked for me. Good luck!
Old Oct 26, 2012 | 06:39 AM
KiowaGuy's Avatar
I concur with the previous post. Every winter my light kicks on with the first temp drop. In order to get it to go off I have to over fill by about 5 psi. I drive it for a little while and drop it back to the preferred psi at the end of the day when time permits. This far has worked every time.
Old Oct 26, 2012 | 07:52 AM
Thanks guys...Put more air this morning will drive home...let sit and then
take air out back to normal...
Old Oct 27, 2012 | 04:00 PM
imacb278's Avatar
Veteran: Navy
Same deal, had to overfill for the light to go off.
Old Oct 29, 2012 | 02:59 AM
Well light is still on...No biggie...Added 5 PSI more drove around let it sit then put
in back down to 30 PSI...Light still on...
Old Oct 29, 2012 | 04:02 AM
Gkarshens's Avatar
Check the spare. Mine came on when it got cold. Filled the 4 on the ground but forgot the spare. Once I remembered to fill it the light went off.
