is tire width as much of concern for rubbing as height?
Old Mar 26, 2009 | 03:41 PM
G DIESEL's Avatar
Default is tire width as much of concern for rubbing as height?
I'm doing aftermarket 18's and I want to run a 33x12.5 tire. Just a leveling lift and I know the 33 will be tight, but just street use and sand. Is the added 1" width a concern? It's a 18x9 wheel, can't get the other specs b/c discounttiredirect website is down.
Old Mar 27, 2009 | 07:14 AM
G DIESEL's Avatar
ANYONE??
here's the specs:
Offset: +30mm
Backspacing: 5.90
18x8.5 wheel
Old Mar 27, 2009 | 08:58 AM
robin's Avatar
I think you're going to have a problem with the backspacing, IMO you need at least 4.75.
Old Mar 27, 2009 | 10:42 AM
G DIESEL's Avatar
Thank you I will look at other wheel options, see if I can find that backspacing...I dont mind if they stick out, actually I like that look.
Old Mar 27, 2009 | 11:33 AM
nthinuf's Avatar
Browse the Wheels and Tires section
https://www.jk-forum.com/forums/modified-jk-tech-2/modified-tech-faq-answers-questions-every-newbie-has-18617/
See if that helps any...
Old Mar 27, 2009 | 12:46 PM
G DIESEL's Avatar
https://www.jk-forum.com/forums/showthread.php?t=18617
that does thanks, looks like I will have to do a 17" wheel to get that back spacing but still do a 33x12.5x17 probably a Dick Cepek or Cooper. Can't wait!
