Tires
Ok since most 37s run around 35.5-36" will they fit on a 2.5 lift with out rubbing issues beside the pinch seams. Will they hit the fender when flexed?
I'm asking cause I measured my Nittio 35's an they measure 33.5 an I only have bout 8k on the I'm running a 9" wheel I know that will take off some height but I measured my spare which never been used an it comes out to 34.25.. So I'm guessing that the wheel is taking bout a 1/4 away from the height.. I just can't see that tire wear 3/4 already with less that 10k on them
Originally Posted by mook8651
Still duno how they wore that much in a short amount of time
you might be able to get away with it if you run flat flares... when the lift kit company says you can run 35's with their kit they mean the size printed on the tire not the size measured. When they test their kits they using the same tires we are buying so if they could get away with saying a kit works with tires that said 37 on the side they would say the kit can run that.
They may rub the inner front inner fenders a little at full lock when flexed regardless. Matt5GT is running 37" Nitto Trail Grapplers on a 3" Full Traction lift with flat fenders and has minimal rub.
