Tires...
I've read at least 100 threads on this. So not sure if you can tell but I'm in germany at the moment but will be back in Merica! In May after a few months on a beach I will be shipped off to alaska.
I've narrowed my tire picks down to this.
In January I can get new KM2s in 37/12.5 17s for the price of $1390 for 5! Right awesome I know.
That or I can wait until the states and get
35s in MTRk, duratracs or the new bfg tko2. For 1500 or more.
So should I pull the trigger and get the km2s here for much cheaper or wait and get a slightly better tire. Or are the km2 a better.
My wheeling is doing whatever is around me, in germany it's a lot of clay hill climbing, watery mud and some rocks.
Back home it's beach so fresh powder sand.
Alaska will be everything.
With 2 kids winter traction matters but my rubicon take offs are bearable in the winter so will any if these tires be worse?
Thanks in advance.
Thanks in advance.
Oh my jeep is on a 2.5 tf lift and these wheels are going on stock takeoffs with spacers. Will be adding a small spacer lift, body lift or chopping fenders so the 37s can fit. One day I will upgrade to teraflex 3 or rk/metalcloack 3.5.
Thanks in advance.
Thanks in advance.
http://www.tirerack.com/tires/tires....yes&tab=Survey
Well the km2s measure out to like 35.5 to 36 and way less than most 35s. I'll have to add a small spacer lift, chop fenders or body lift(this might be hard with rr snorkel). My main worry is gearing but considering after a few months I'll have a year to save for a prorock 44 front I think I can handle it in the mean time. Since they're so close to a 35 I don't see many problems.
On a 2010 automatic I would max out at 35" and you should really be thinking about adding $1500-2000 in gearing costs to run them. Personally I would run 35" Duratrac's and re-gear the axles to 5.13 and add lockers and cromoly rear shafts.
I don't want to regear yet since I plan on buying a built 44 after Korea then regearing the back myself. Just need tires for the next couple of months here and then I'll build the jeep and take it to alaska.
