Toe rod end on passenger knuckle spinning
Old Mar 5, 2013 | 04:29 PM
Paws's Avatar
Trying to losen or tighten the drag link end link and the ball joint keeps spinning. How can get this tightened? It's the last thing I need to make this lift complete. There is a little play when moving the drag link with hand.
Installed RK 3.5 max travel.
Edited with correct part...
Old Mar 5, 2013 | 04:43 PM
c4bus's Avatar
Put a jack under the tie rod and jack it up til there is enough pressure. This should stop it from spinning so you can torque it.
Old Mar 5, 2013 | 05:02 PM
Paws's Avatar
Ugh stupid me. That should be the drag link I'm having issues with. I've tried turning the steering wheel and the nut is still stuck.
Old Mar 5, 2013 | 05:09 PM
familytime's Avatar
JK Forum Regional Rep
On the stud of the joint there's an a place for a allen wrench to fit in to hold the joint from turning while tightening the nut
Old Mar 5, 2013 | 05:35 PM
c4bus's Avatar
If you don't have an Allen that will fit try using a hi lift out pressure on it. Worst case scenarios JK tie rod nuts are nylock, so a torch will melt it enough to unlock it and you can grab a new one at the dealership. They're $2
Old Mar 5, 2013 | 06:01 PM
Paws's Avatar
Thanks guys!
Family time you are my hero. Now my jeep drives better than stock. Thank you!
I don't know how many times I handled that end link and never noticed that. Wow.
