toe in or toe out?
Hello all, i have read the write up on front end alignment and i was courious about the toe out for 37" or larger tires. i know it suggest a toe out for that size tire but what if you bounce back and forth between a 35" and a 37" tire? i use my 35" for the colder months and 37" for the summer months. does it really matter if i leave a toe out for the 35"? ant potential problems?
Toe OUT for larger than stock tires is incorrect. Tires are exposed to a "pushing" effect as they are driven down the road. This pushing effect pushes the front of the tires towards the outside of the vehicle. Of course, because of steering linkage, they cannot move much, but this push can certainly be measured on an alignment machine. Larger tires require more toe IN because of their increased leverage allowing more of the road push to occur.
this is absolutely correct. in virtually all cases, toe-out is incorrect for a rear wheel drive vehicle and for the reasons stated. so that it's clear, what i wrote is strickly based on what i have seen other guys do in the past and yield the results they were looking for, hence, why i say "you may actually want...." as opposed to saying something like "you need to..." for whatever it's worth, i run close to a factory toe-in even with my 37's and it seems to do the job well.
Toe out causes wander- the vehicle doesn't know which tire to follow. Also the inside tread on each tire would be history in a very short time. A slight TOEIN is required to get the front tires to work in tandem, meaning a slight PUSH against each other. This causes the vehicle to track straight and true. It takes VERY little toein to accomplish this....
Kurt
