Tom Woods driveshaft
I have a 1310 tom woods driveshaft
The cv joint part is clicking, its not a u joint. Can something like that be picked up at the parts store |
Not likely.
Contact Tom Woods. Which drive shaft? How much lift are you running? |
Its the rear and its 6 inch lift
I greased everything up when I changed the oil last week but that cv joint fitting was impossible to see unless I took the whole shaft off so I didnt know it was even there. |
That's a lot of lift.
Did you talk to TW when you ordered the shaft and tell him the amount of lift. If so, I am little bit surprised he didn't recommend dual-cardan shafts. How is the front one doing? |
It is double cardan there is the cv joint in between the two u joints at the transfer case:thinking:
I told mbatf what i had he told me what to measure The fronts fine and the rear was fine untill a few days ago. |
My suggestion, drop the ds , inspect for play, change u-joints while your at it and grease that center cv joint. You may not be able to tell a u-joint is going out until you drop it. Clicking could be a needle bearing. How long has the shaft been on?
6 months 6000 miles
I already pulled it off the play is in that cv The u joints were good you move that cv back and forth and you can hear it click Guess Ill just call monday and see what they want to do. |
How bad is the pinion angle?
Hey bud.
TW offers 180 days factory warranty. Contact TW directly and your info should still under Alpha Expedition. |
Thats the part I got the part number here. Is it difficult to replace?
| All times are GMT -8. The time now is 02:38 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
