Tom Woods driveshaft
Old Mar 6, 2010 | 10:30 AM
Pauls09jk's Avatar
Default Tom Woods driveshaft
I have a 1310 tom woods driveshaft
The cv joint part is clicking, its not a u joint.
Can something like that be picked up at the parts store
Old Mar 6, 2010 | 12:02 PM
spinlock's Avatar
Not likely.
Contact Tom Woods.
Which drive shaft? How much lift are you running?
Old Mar 6, 2010 | 12:06 PM
Pauls09jk's Avatar
Its the rear and its 6 inch lift
I greased everything up when I changed the oil last week
but that cv joint fitting was impossible to see unless I took the whole shaft off so I didnt know it was even there.
Old Mar 6, 2010 | 12:39 PM
spinlock's Avatar
That's a lot of lift.
Did you talk to TW when you ordered the shaft and tell him the amount of lift.
If so, I am little bit surprised he didn't recommend dual-cardan shafts.
How is the front one doing?
Old Mar 6, 2010 | 01:57 PM
Pauls09jk's Avatar
It is double cardan there is the cv joint in between the two u joints at the transfer case
I told mbatf what i had he told me what to measure
The fronts fine and the rear was fine untill a few days ago.
Old Mar 6, 2010 | 02:03 PM
mkjeep's Avatar
My suggestion, drop the ds , inspect for play, change u-joints while your at it and grease that center cv joint. You may not be able to tell a u-joint is going out until you drop it. Clicking could be a needle bearing. How long has the shaft been on?
Old Mar 6, 2010 | 02:20 PM
Pauls09jk's Avatar
6 months 6000 miles
I already pulled it off the play is in that cv
The u joints were good you move that cv back and forth and you can hear it click
Guess Ill just call monday and see what they want to do.
Old Mar 6, 2010 | 04:19 PM
nangulator's Avatar
How bad is the pinion angle?
Old Mar 6, 2010 | 06:06 PM
MBATF's Avatar
Sponsoring Vendor
Alpha Expedition
Hey bud.
TW offers 180 days factory warranty. Contact TW directly and your info should still under Alpha Expedition.
Old Mar 8, 2010 | 10:37 AM
Pauls09jk's Avatar
Thats the part I got the part number here. Is it difficult to replace?
