Too much Toe-in
Old Aug 4, 2011 | 02:15 AM
EzK's Avatar
EzK
Originally Posted by mkjeep
Hmph,with those specs your total toe would be .40, almost 1/2in. Your tires are gonna chew up in the front, I know this from experience.
Degrees are not = to inches.
Old Aug 4, 2011 | 07:14 AM
RubiconRod's Avatar
So do I have too much toe-in?
Old Aug 4, 2011 | 08:18 AM
mkjeep's Avatar
Close enough in toe. Not exact, but if you use a tape measure to set your toe, then put it on an alinement machine ,it's not to hard to figure out.
Old Aug 4, 2011 | 08:20 AM
mkjeep's Avatar
Yes. Just have them set it within factory specs. A good alinement guy will know how to set your toe.
Old Aug 4, 2011 | 08:25 AM
Freewill's Avatar
Originally Posted by orfanidisnikolaos
As far as i know you cannot adjust camber in a jk, cause it has solid axles.
Truel. I was thinking of front ends in general. Far as I know you are shopping for a new axle housing if the JK camber is out, although replacing the "C" bracket might work in some cases.
Old Aug 4, 2011 | 09:28 AM
mkjeep's Avatar
Camber can be adjusted to within spec if it is out by installing adj. Ball joints.
Old Aug 4, 2011 | 09:30 AM
mkjeep's Avatar
As I said in previous post, if camber is out, it can be fixed with adj ball joints.
Old Aug 4, 2011 | 09:34 AM
RubiconRod's Avatar
Roger that. What's your opinion on my caster which is just above factory specs?
Old Aug 4, 2011 | 09:46 AM
SilverJK12's Avatar
5-6 is a good castor from my pov
Old Aug 4, 2011 | 09:59 AM
mkjeep's Avatar
X2........
