Tool Requirements for Efficient Installation...
Guys -- does anyone have a comprehensive list of every tool that is needed to install a 4" TF lift w/shocks? I also have TF front/rear adj. control arms...I checked the installation instructions, but I didn't see a tool list, and without actually doing the work, it's difficult to determine all the necessities. I'd like to know I have everything before I begin the installation so that it is time-efficient. Thanks in advance!
outside the obvious (jack, basic wrenches... etc)
sockets up to at least 21-22mm, i had to get a 24mm recently, but i cant remember if that was for my bumper or a lower control arm, or a trac bar... rubber mallet, crow bar, if you have a rear trac bar bracket to put on, i recommend welding it on
You might check out one of the 4" lift installation write-ups. That should give you a good idea of what's entailed and what tools you'll need. Read over it carefully because there may be a tool they list for a part that is not included in your kit ...
http://project-jk.com/jeep-jk-write-ups/rough-country-jeep-jk-wrangler-4-suspension-lift-installation-write-up
http://project-jk.com/jeep-jk-write-...ation-write-up
i have all the tools you will need for this exact lift listed on this write-up
