Torque Specs Lubelocker vs RTV
I picked up a Solid diff cover off of a forum member on here that already had a Lubelocker gasket. Threw it on yesterday torquing the bolts to 30 lbs. Looks like it dripped once or twice over night. Are the specs for a Lubelocker gasket the same as RTV or more?
The first step is to torque to 15ft/lbs and then the second is to torque to 35ft/lbs. In all seriousness though, if you don't have a torque wrench, just put it on following the torque pattern and you should be good.
