Torque steer issues
Old Jun 28, 2015 | 04:51 PM
jeeperz2's Avatar
Default Torque steer issues
Anyone know how to fix some seriously bad torque steer? Steering wheel spins left on take off and abruptly spins left when I let off throttle. I have a rough country 6" long arm, coilover conversion, synergy high steer, and 37" tires.
Old Jun 28, 2015 | 04:58 PM
lkjk's Avatar
Sounds like a toe issue, check that. It's unlikely it's related to torque steer because A) its a jeep there is no torque and B) its RWD or 4WD
Old Jun 28, 2015 | 07:42 PM
D_engel's Avatar
Do you have a rear trackbar bracket? Post up some pictures of your steering set up and we can help you out.
Old Jun 28, 2015 | 09:58 PM
nthinuf's Avatar
What are the Caster and Toe specs?
That lift comes with a drop pitman and drop trackbar bracket? Are they installed? (or are you currently running 'only' the stock pitman and the synergy axle-side trackbar bracket and a flipped draglink?)
The kit comes with a rear frame-drop trackbar bracket? Have you considered replacing it with a raised axle bracket?
Old Jun 29, 2015 | 04:58 AM
kjeeper10's Avatar
Vet Army
Factory axles/caster?
Old Jun 29, 2015 | 06:07 AM
JoeK's Avatar
lol yupp
