Towing Capacity Question
Old Sep 12, 2013 | 05:16 PM
Joeq333's Avatar
Default Towing Capacity Question
I have a 2007 4-door Wrangler, manual transmission with a 3" suspension lift. Am I still good to tow a 2000lb pop camper or does the lift mess things up?
Thanks
Old Sep 12, 2013 | 05:20 PM
kh202's Avatar
Thanks
What gears? Friend of mine towed my 2000-2500 lb boat/trailer 650 miles to me with his 2007 with 3" TF lift, 35's and 3.21 manual.
Old Sep 12, 2013 | 05:22 PM
Creepwithjeep's Avatar
Do you have a tire size other than stock? And are your axles still stock?
Old Sep 12, 2013 | 05:23 PM
ronjenx's Avatar
Do you have 3.21 or 4.10 gears?
3.21 = 1000 lbs. tow rating.
I wouldn't say the lift messes things up for you, but it should make you a lot more careful, especially when towing.
Old Sep 12, 2013 | 05:32 PM
Joeq333's Avatar
Default More info
Tire size went up to 33 from 31, axles are stock and gears havent changed either
Old Sep 12, 2013 | 05:34 PM
ronjenx's Avatar
Stock gears, but that could be 3.21 or 4.10.
Old Sep 12, 2013 | 05:41 PM
nthinuf's Avatar
It will be more gutless than normal. 2k behind a 4door, even with stock gearing, shouldn't be a problem. (w/ a tranny cooler for the autos, of course)
I wonder if that 1,000 lb limit on 3.21's is just because they don't have the tow package? So assuming he has a class 2 or better hitch and wiring and all, should be good to go?
Old Sep 12, 2013 | 05:52 PM
ronjenx's Avatar
The 1000 lb tow rating has to assume a tow package because it's giving a rating for towing. Can't tow without a tow package, which is just a hitch and wiring on the early models.
Old Sep 12, 2013 | 06:05 PM
nthinuf's Avatar
Yeah, I was thinking about people with other bumpers just slapping a ball into the hole in the bumper, or a JK slapping a class 1 hitch on, rather than using a beefier frame mount.
I just can't see a 2500 lb difference simply because you have 3.21 vs 3.73.
Old Sep 12, 2013 | 06:17 PM
jeeperjkjeeper's Avatar
I pull a fully loaded pop up all summer long and have for the last 4 years. I average about 2500 lbs and I have a 4 dr Rubi with 4.10's, 35" Toyos and a 2.5" lift. No issues what so ever!
