Toyos on Stock 18s
Old Dec 25, 2008 | 08:16 PM
Optus's Avatar
Default Toyos on Stock 18s
Hey guys,
Im ordering the toyo M/T tomorrow for the stock sahara rims. its the 33.6x11x18 so my question is, am i going to need spacers?
Sorry if this was already answered somewhere i searched but couldnt find anything.
Old Dec 25, 2008 | 08:59 PM
Zylfrax791's Avatar
Originally Posted by Optus
Hey guys,
https://www.jk-forum.com/forums/show...74&postcount=3
Old Dec 26, 2008 | 07:14 AM
JeffD's Avatar
I am considering a similar sized tire and will have the RC 2.5" Spring Boost. I have read the FAQ that Zylfrax noted (although it only kinda sorta maybe answers the question). (OT-By the way, I have a couple of offices I manage in Lake Oswego...get over there a couple times a year).
My guess is that 33's and 34's will have some rubbing at various full lock and articulation situations that may require spacers. I am torn between spacers and wheels, as I really don't want to do either but wouldn't mind just a bit more tire.
My recommendation would be to go for it, then if you need spacers, get them. I am NOT a Jeep expert (total NEWB here), but again, the threads I have found on this topic exactly seem to indicate that you are mostly ok, but may see some rubbing at the edge of the envelope. I am not getting new tires until Spring, so let me know how it turns out for you.
Old Dec 26, 2008 | 07:46 AM
britjk's Avatar
Hey guys,
In my opinion you will have to but I could be wrong. I had to with my 305/65/18's.
Old Dec 26, 2008 | 08:45 AM
Fermin's Avatar
you will need spacers
Old Dec 26, 2008 | 09:34 AM
Optus's Avatar
in the thread posted it says,
Q: What back spacing will I need on my wheels in order to clear 12.50 wide tires?
A: I would recommend that you do not exceed 4.75" of back spacing and even at that, you may still have some minor rubbing up front at a full turn. Also, I would recommend that you do not go any less than 3.75" as anything less would cause your tires to stick out very far past the fender flares. Any back spacing within this range should work out great.
With a 12.5 tire and 4.75 back spacing, that would bring it up to 6.25 with the 11" wide tire so it should be okay with maybe a little bit of rub?
Old Dec 26, 2008 | 09:49 AM
Fermin's Avatar
I'd imagine that you would still need 5" Back Space. You aren't just concerned on rubbing the fenders. Also don't want to run your plastic air dam and any of the rods on the inside of your wheel well either.
Old Dec 26, 2008 | 11:11 AM
Optus's Avatar
right which is why the 6.25 would be sufficient if what that question is saying right?
Old Dec 27, 2008 | 11:19 AM
Optus's Avatar
i stopped at the local shop on the way home today and they said that it shouldnt be a problem so im gonna go ahead and order these and see what happens
Old Dec 28, 2008 | 05:51 PM
britjk's Avatar
It's your Funeral.
