TPM Question
Old May 12, 2008 | 10:01 AM
boots's Avatar
Default TPM Question
Ok Guy's and Gal's,
I need some information on TPM's.
After changing over from the stock wheels and tires, to the AEV Printer wheels with the stock TPM's and 37" Goodrich KM2's. I have ben doing some adjustments to tire air pressure to get the best ride and wear pattern for the tires.
I started at 35lbs and now I am at 30lbs for the rear tires and 31lbs for the front. This gives me a perfect tire patch on the road.
NOW her is the problem. At 35lbs I got no TPM light on the dash. After adjusting air pressure (to numbers above 30lbs rear and 31lbs front) I now get the TPM light on. Is their a way to adjust the TPM settings so the light stays out ? Other than going back up to 35lbs.
Old May 12, 2008 | 11:12 AM
Littlejon's Avatar
I have heard that the dealer can re-flash so that the threshold where the light comes on is 28 psi. I know I had this done on my Liberty, and will probably have the same done when my JK arrives.
Old May 12, 2008 | 01:26 PM
boots's Avatar
Thanks, never heard of this before. Will stop by my dealer on the way home from work on tues. any see what they say.
