Tpms
Old Jan 11, 2012 | 10:34 AM
Spinall4's Avatar
Default Tpms
K I had tires put on last night and they said my tpms sensors are cracked and beat up. I want reason to take them on anyways. My question in with the super chips can u turn off the tpms system and just put normal valve stems in ?
Old Jan 11, 2012 | 10:36 AM
Ringer's Avatar
I believe the AEV Procal is the only one that lets you trun off the TPMS. I have it and it worked great. TPMS is only for those who don't check tire pressure. You have a few Ford Explorers roll over, and everybody needs expensive valve stems!
Old Jan 11, 2012 | 10:37 AM
RELENTLESS's Avatar
You can lower the tpms settings so the light doesn't come on till the pressure in the tire reaches whatever you have it set for but you cannot disable the whole tpms feature
RELENTLESS's Avatar
Oh..... well obviously I was wrong
Old Jan 11, 2012 | 10:38 AM
RubiconRod's Avatar
Superchips allows you to do this but I think you need to download the special module to do so.... Don't recall right now...
Old Jan 11, 2012 | 10:45 AM
msells32's Avatar
You do have to do the update then plug back into jeep and select option, worked great on my 2010.
Old Jan 11, 2012 | 11:44 AM
Spinall4's Avatar
U guy think I can take the wheel off and pop the bead on the tire on the floor air air it back up bymyself if I take the valve stem out?
Old Jan 11, 2012 | 12:22 PM
Spinall4's Avatar
Bumpto top
Old Jan 11, 2012 | 05:51 PM
PhantomRescue's Avatar
Yeah, breaking and reseating a bead will likely not happen in your garage with seriously risking a little too much. If the tire is off already, just take it to a shop and it should not cost you more than ten bucks to get them to take it out.
Old Jan 11, 2012 | 06:33 PM
AirForceMike's Avatar
^^^ This. I bought new wheels and don't have any TPMS sensors installed at all. Bought an AEV Procal and set it to 0, no light ever. Just make sure you check your tire pressure every so often
