Tpms
Old Oct 13, 2008 | 05:21 AM
JUS 1 MO's Avatar
Default Tpms
I received my new ProComp wheels and Nitto TG tires this weekend. I installed them and went for a test drive. They are great.
In a tread somewhere on here, someone asked about the running of a wheel and tire package without TPMS sensors and I just wanted to report my findings. The warning chime, nor the light came on. Maybe it's because i left my OE spare on and the computer thinks everything is ok. At any rate, I'm pleased with it not working.
By the way, these Nitto tires and ProComp wheels have less balancing weight than any set that i have ever had. When I received them, I just knew that i would have to have them rebalanced because of the lack of weights. Not so, they are perfect...
Old Oct 13, 2008 | 05:32 AM
AlmightyCrash's Avatar
the light/chime will come on eventually unless you have all five. However, most aftermarket wheels will accept the sensors from the stock wheels. you just have to have them switched out. its built into the valve stem.
Old Oct 13, 2008 | 10:56 AM
aldaman's Avatar
Originally Posted by JUS 1 MO
........and I just wanted to report my findings. The warning chime, nor the light came on. Maybe it's because i left my OE spare on and the computer thinks everything is ok. At any rate, I'm pleased with it not working....
Originally Posted by S10x1000
Yea buddy its coming. My light didnt come on for 3 days after i switched tires.
Same here....I noticed it's also mileage sensitive. I still have my stock tires with the TPMS mounted & stored in the garage, so when the JK is parked overnight the (!) will shut off; but when I drive over the distance of 14 miles the ding & light (!) comes on...No biggie for me though...
Old Oct 13, 2008 | 11:53 AM
JUS 1 MO's Avatar
How long does the chime last? Does it stop after the warning?
I can live with the light.
Thanks
Old Oct 13, 2008 | 12:29 PM
aldaman's Avatar
Thanks
Usually goes away after the 4th ding @ start up....
Old Oct 13, 2008 | 04:03 PM
backdoc94's Avatar
They may seem silly but the TPMs are life savers. Keep them if you can, they should mount to any wheel. A tall tire that loses air can flip your rig. I did a mud run a few years back with about 15 psi in the tires. At the end of the day I filled the tires to 35 for the trip home but mud got into the bead and let air out one of the front tire slowly. During the drive home I went around a corner at normal speed and lost control due to the tire having almost no air. I could not tell going straight. Fortunately there was nothing to hit and all was ok but if that rig have the TPMs it would have warned me.
Old Oct 14, 2008 | 01:16 PM
Ben's Avatar
Ben
is it possible to shut off the tpms system? It bugs me and I kept the sensors in my stock wheel/tires cuz I put most of my mileage on them. If not can you buy the tpms sensors seperately? Do they have to come from Mopar?
NM, you can buy them but they are way more than I am going to spend. I want to pull a fuse or something!
Old Oct 14, 2008 | 01:22 PM
Mossyoakman3006's Avatar
Pardon my ignorance but what are these sensors and do all JK's have them?
Old Oct 14, 2008 | 01:34 PM
Ben's Avatar
Ben
Hey your ignorance has been pardoned my son.
TPMS is the system that alerts you to low tire pressure.
The sensors are in the valve stems of your tires. They transmit via radio waves to the computer. If a significant drop in pressure occurs, (or if the sensors aren't there,) it trips a warning light in the dash and also chimes/blinks at you everytime you start it up.
Nevermind I found my answer I got an 07 so I dont have to worry about it
