TPMS and airind down
Old Jul 20, 2010 | 07:30 AM
spleify's Avatar
Default TPMS and airing down
Are there any ill effects from airing down for offroading with the TPMS? Is there just a light that will show me I have insufficent air pressure, or is there more to it?
Thanks
Old Jul 20, 2010 | 07:33 AM
Brashanic's Avatar
just the light. and a chime for each low tire
Old Jul 20, 2010 | 07:54 AM
spleify's Avatar
Right on! Thank you kindly!
Old Jul 20, 2010 | 09:00 AM
scoped's Avatar
ya its awesome!!! i get to hear and see it every time i start the jeep need me a superchips
Old Dec 21, 2010 | 11:35 AM
COZDONO's Avatar
After airing down then back up do the TPMS reset?
Donnie
Old Dec 21, 2010 | 11:43 AM
nthinuf's Avatar
The ill effects are that the sensors are cheaply made, very, very easy to break, and they get quite expensive to keep replacing. I would suggest you consider a procal or flashpaq rather than replace them...
And yes, the system will reset after airing back up. Some have indicated that it may take a while for the light to turn off, so just give it some time if it stay on.
Old Dec 21, 2010 | 11:51 AM
Red Dog's Avatar
You can get a Procal from AVE for about $150 and it will let you reset the tire pressure threshold down to zero. The Superchips is $300+ and will only go down to 16 PSI I think (check with manufacture, not on website).
Old Dec 21, 2010 | 11:52 AM
nthinuf's Avatar
The flashpaq can disable also.
Old Dec 21, 2010 | 12:09 PM
yomondo's Avatar
You can download (for free) a module for the Superchips Flashpaq to completely disable the TPMS. Flashpaq also has a few other features that Procal doesn't, but if all you're after is disabling TPMS, Procal is probably the way to go.
Old Dec 21, 2010 | 12:22 PM
dadgummit's Avatar
My superchips will let you set the TPMS to anything from 26psi on up or you can disable it alltogether. It will not let me set it between 1 and 25 though. Nice feature off road so you don't get the chimes every time you start up.
