TPMS Work Around
Maybe you good folks can help. It recently sold all five rims/tires off my 08 Rubi to a friend who has a Sahara. I in turned got her five TPMS sensors from her rims and put them in a PVC tube pressurized to 55 PSI. I put this tube in the glove glove but the TPMS is still flasking...what do I need to do now?
Thanks!
Thanks!
My wife's '08 has the wheels from my '07 which does not have TPMS. Right now, she just deals with it- says it doesn't bother her one bit. But TX has yearly safety inspections. Actually, new cars are exempt the first year, so she has 2 years before she has to deal with it. And in TX, if a car came equipped with TPMS (as all cars from '08 on are) then it must function in order to pass the inspection
So ultimately we will need to do something about it.
So ultimately we will need to do something about it.for inspection... works out if you have a friend you can swap wheel and tires with for a day.
Actually, the sensors shut down after a certain period to preserve batteries. Once motion is detected they fire back up again. At least that's the way most of them work.
Putting them in a tube is part of the solution. Moving the tube enough to activate the TPMS is the trick.
Let us know if it works out!
Almost all TPMS have XZ-axis accelerometers embedded to sense motion. There is a 10-year requirement for the sensor battery - that's why they have shut-down logic (trying to preserve the battery). Should be interesting in 2018 when all of the 1st gen TPMS's start crapping out!
