Track bar
Old Feb 4, 2014 | 12:13 PM
ronixwrangler's Avatar
Default Track bar
How to get this hole lined up!!?! :-/
Old Feb 4, 2014 | 12:23 PM
ronjenx's Avatar
I had some one push the body to the side while I installed the bolt.
Old Feb 4, 2014 | 12:24 PM
myrojk's Avatar
sent from the Bottom of the mud pit
Old Feb 4, 2014 | 12:31 PM
Can I wait till u put tires and everything on and drop it to the ground then put in bolt? I can't get it
Old Feb 4, 2014 | 12:40 PM
Grant09's Avatar
Yes, you can do this after you get it back on the ground. Or, the other suggested way is to use a ratchet strap and connect one end to the axle and the other to the frame and use the ratchet to pull it in line.
Old Feb 4, 2014 | 12:59 PM
Monte417's Avatar
put it on the ground. turn the steering wheel until the bolt hole lines up. done
Old Feb 4, 2014 | 01:15 PM
meep97's Avatar
Put the wheels on the ground. Start it up to make it easier to turn the wheel. Turn the wheel until holes line up. Shove bolt in. Put nut on. Torque to 125 ft lbs. Get drunk.
Old Feb 4, 2014 | 05:33 PM
Perfect, i took the put it on the ground method and it worked great. Thanks for all of y'all's help.
