Track bar
Old Apr 9, 2020 | 05:52 AM
ericocas's Avatar
5 Year Member
Default Track bar
Need some opinions if possible I知 getting ready to put a 3 inch lift BDS on my two door JK 2011, I知 installing the front control arms uppers and lowers but my question is how much is my front going to be off-center if I do not install a tracking bar,
Old Apr 9, 2020 | 05:54 AM
karls10jk's Avatar
BDS is not a great kit to install and the axle will be very far off with 3" of lift. Buy the track bar please. Hopefully you have something planned for the rear as well, like an axle side bracket to raise the track bar mount in addition to a longer bar.
Old Apr 9, 2020 | 06:00 AM
ericocas's Avatar
5 Year Member
Default T bar
The kit came with a rear drop down bracket for the factory bar, I知 getting the kit installed Saturday so it痴 probably too late to order a front tracking bar, if I see it痴 going to be off that much I値l bring it home leave it and buy a new tracking bar adjustable from TeraFlex, thanks for the info
Old Apr 9, 2020 | 06:12 AM
TheDirtman's Avatar
Drop brackets are a poor way to go. So is BDS. You should raise the axle side bracket. You will want a front adjustable track bar. You will have better handling on road.
Old Apr 9, 2020 | 06:23 AM
ericocas's Avatar
5 Year Member
Hey thanks for that information I値l see what I can do with that rear track bar, as far as the BDS suspension kit too late for me now it痴 already getting ready to be installed, It痴 a daily driver for me anyways and I never go off road so hopefully it値l work out, I just wanted to dress up that JK a little bit
Old Apr 9, 2020 | 06:31 AM
jadmt's Avatar
JK-Forum Ambassador
well some don't like the bds (big dick suspension) I know people who are pretty hard core that run them and do great. No way of knowing how far off centered your front axle will be until you have the lift on. I have installed 3.5" lifts and the front axle was with in 1/4" in so every jeep is different. One thing is that kit generally comes with cam bolt adjusters to adjust caster. I would make sure you get either adjust lower front control arms or if for what you describe never offroad get geobrackets. they will do three things. give you a smoother ride on the small bumps, correct your caster and keep your front drive shaft happy. AEV ones are $105 and money well spent.
Old Apr 9, 2020 | 06:48 AM
ericocas's Avatar
5 Year Member
That痴 good to know, for the control arms i am installing new uppers and lowers I wanted to make sure my geometry was back to stock, like I said I値l get the jeep home I値l check the center of how the frontend looks like, then I will order front and rear new tracking bar, It痴 just gonna be a daily driver so I just wanted to get it back so it rides pretty smooth
Old Apr 9, 2020 | 06:53 AM
jadmt's Avatar
JK-Forum Ambassador
geo brackets ride smoother than having adjustable control arms.
Old Apr 9, 2020 | 07:06 AM
resharp001's Avatar
Loved
Community Favorite
The flaw in your thinking here is that it takes a lot of effort to maintain a nice pavement handling machine. That is precisely why you want nice quality components and make sure you address all aspects. It has very little to do with aggressive offroading. Your logic is reverse.
Old Apr 9, 2020 | 07:30 AM
ericocas's Avatar
5 Year Member
I知 thinking of going with the rough country adjustable track bar壮 front and rear, I think the extreme terrain bars are a little bit too heavy duty for what I want to do,
