Track bar bolt help...
I'm usually really good about noting things when I remove them. Put a lift on and have to put the rear track bar back on, except I forget which way the bolts go. Can someone help me with the following two questions?
1. There is one bolt with a tabbed nut - does that go on the passenger or driver side?
2. Which side does the nut go on for each of the rear track bar bolts (i.e. which direction do the bolts go to avoid any clearance issues)?
Thank you!
Thank you!
Rear track bar bolt with flagged nut goes axle side. The head of both bolts face the rear. I switched the frame side bolt so the nut faces the rear. Couldn't get a torque wrench with it on the other way. No clearance issues.
