Track Bar Bracket at Axle
Old Mar 25, 2009 | 12:39 PM
Jeff09's Avatar
Default Track Bar Bracket at Axle
Hi,
Sorry for the double-post. (I asked this question in another thread; but, I am afraid it might be overlooked.)
I am almost complete with the install of the OME LT kit from David at Northridge. I am installing this kit on an '08 JK Rubicon 2-door. Part of that kit includes adjustable track bars for the front and rear.
I have searched for an answer to this question; but, I haven't found anything that really makes me comfortable.
I believe that I have read in other threads that there is a potential problem with the stock track bar bracket (axle side) on JKs. Or, am I mistaken?
Should I be considering having new brackets installed on the JK for the track bars? I don't see any extreme wheeling in my near future; but, I'd like to be prepared.
Thanks
Jeff
Old Mar 25, 2009 | 12:42 PM
JKRockStomper's Avatar
You should be fine with the original. Just check it for any signs of fatigue (e.i. cracks or busted welds).
Old Mar 25, 2009 | 12:55 PM
Jeff09's Avatar
Default Thanks
Hi JKRockStomper,
Thanks for your opinion. ( One less thing to spend money on.)
Jeff
Old Mar 25, 2009 | 01:30 PM
yoshillopez's Avatar
If, in the future, you want to strengthen the axle side mounts check out the braces that JKS provides. Really beefy and substantial. I addressed the track bar mounts before installing the lift (I have the OME HD), just to give me some peace of mind.
Old Mar 25, 2009 | 02:06 PM
RCJeeper's Avatar
What size lift are you installing? What size tires do you intend to run? I would consider beefing up both front and rear axle brackets. I have heard of failures on even moderately wheeled JKs with lifts.
Even before the my JK ever saw dirt I welded on mine.
Old Mar 25, 2009 | 03:06 PM
-MAW-'s Avatar
if you run an adjustable tracbar you should not worry because the force applied to it remains the same there is no leverage like if you used a superlift or skyjacker braket
the drop brackets are aswell safe too
