Track bar or CAs?
I recently installed the teraflex 2.5 coil lift in my 2012. The steering is a bit flighty. Should I get an adjustable track bar next? Adjustable control arms? Not sure how each effects the geometry and which if either would help tighten up the steering. Also have Duratrac 315/75/16 on order, if that has any bearing.
So what's first? I know the axle isn't very far off center with my 2.5 lift, or at least doesn't appear to be... So LCAs? Or should I just bite the bullet and do both now? What does the drag link flip change?
Changes your steering geometry by raising your trackbar 3". I went with a drop pitman arm to correct my bump steer but have since learned(and ordered) that the flip kit is a better solution. You are really not supposed to need one with only 2.5" of lift so I am pretty positive that someone else will chime in with a better solution.
The ultimate goal is to eventually add either 1" spacers or 3.5" coils... But it's a money process, as I'm sure you know. I'm still running stock shocks, so another inch is going to call for better shocks, probably a new front drive shaft, well, you know the drill
