track bar mount re-enforcement
Old Jun 15, 2009 | 08:59 AM
fish's Avatar
From: Apple Valley, California Good ole Mojave Desert.
Default track bar mount re-enforcement
after seeing a couple track bar mount failures on the trail i followed another members write up on strengthening the mounting point and decided to do it myself.
made a couple of templates:
cut out the 1/4" thick metal pieces and welded(not a pro welder) them in place:
painted it up:
hopefully it helps prevent the failure.
Old Jun 15, 2009 | 09:31 AM
blockrockin's Avatar
nice job that should make them alote stronger... its no fun when they break..
Old Jun 15, 2009 | 09:32 AM
RedneckJeep's Avatar
Not a pro? It looks great to me. You might think about reinforcment on the frame side too, since you're in the mood. They do break there, as well.
Old Jun 15, 2009 | 09:35 AM
tkob1060's Avatar
From: Hangin in the sunshine state....staging forum..
yep that frame one can be ripped in half if you are real good
https://www.jk-forum.com/forums/jk-trails-tales-71/durhamtown-mid-june-09-a-90064/
Old Jun 15, 2009 | 09:37 AM
fish's Avatar
Thanks guys,still working on my welding for sure RJ , i will check out the frame side
Old Jun 15, 2009 | 09:46 AM
Renzo Fighter's Avatar
i think this is the piece that broke on mine? I had it welded also. What other piece are we talking about that should be done?
Old Jun 15, 2009 | 09:53 AM
bigbluejk's Avatar
so I wasn't just seeing things? Did you get it welded today?
Old Jun 15, 2009 | 11:10 AM
fish's Avatar
frame side failure:
Old Jun 15, 2009 | 11:24 AM
opdsgt's Avatar
I would worry some about welding too much and creating brittleness in the metal, particularly on a small piece like that.
When I had my JKS rear trackbar brace installed, I had a well known welding shop do the work and they stitch welded it. This leaves the piece somewhat unfinished by way of what's welded up, but offers a stronger overall attachment point for the rear SB, this according to people a lot smarter than I am.
FWIW
Old Jun 15, 2009 | 11:28 AM
fish's Avatar
no pro here,we will see what happens
